Trouble With Input on Dynex TV...
Anomaly1964
2,465
8
I have a Dynex DX46L150A11...
I have Verizon for cable and on my other TVs the AVI button will change to the input I need for gaming, dvd, whatever, it won't on the Dynex...
I bought a Harmony 300 which controls the tv, settop box, blu ray, and sound bar...
EVERTYTHING works BUT changing the INPUT...
So if the Verizon nor Harmony remote will do it...any suggestions?
thanks!
CubanlB
562
What buttons on the dynex remote do you have to press to get it to toggle inputs?
There were some Mitsubishi TV's that harmony remotes didn't like. You had to put the remote into discrete mode. (in regular mode you hit input and navigated to the connected device. in discrete mode hitting input and then a number would send the TV directly to a specific input)
The remote should be able to learn the IR command in raw format, which works fine for input selection. Just go through the troubleshooting and you should get to this menu.
Anomaly1964
2,465
8
Good advice...thanks!
