I have a Phantek Evol ATX case with 2 x 140mm SP fans in the front sucking in and 1 x 140mm in the rear sucking out. I have a 120mm radiator uptop with 2 Corsair SP fans blowing air out through the radiator (push configuration.) the cooling solution is a Corsair H110i GTX AIO cooler. I run a GTX 980TI Hybrid from EVGA.
GPU stays around 50-55C under load, but the CPU is the main concern, it goes as high as 60c stock while gaming. If I overclock to 4.5GHZ @ 1.275v it goes as high as 80-85c. I know for a fact my cooling should be doing much better than this, I didnt spend extra on a case/motherboard/fans/liquid cooling and a K processor to NOT be able to overclock 500mhz respectively.
So I have my 120mm radiator mounted uptop with a push configuration, a rear 140mm ran exhausting and 2 x 140mm intakes in the front. I also have my Hybrid radiator mounted as an INTAKE in the front. Should I swap my Hybrid radiator to the rear and use it as a outtake where the 140mm one is? I should not be seeing 80-85c on water cooling @ 1.275v, my 6600K on air cooling in a crappier case was able to do 4.5 @ 1.270 and stay in the 70's so what gives?
I know overclocks arent gauranteed but when I spent an extra $50 on my motherboard, $50 on my CPU, $100 on cooling and I can't even overclock to a measily 4.5ghz that's pathetic...
Also I noticed my fans don't seem to go as fast as they used to, it used to sound like a jet engine when my PC would kick up so I turned the fans down... but now no matter what I do in BIOS the fans won't go any faster, the CPU fans are @ 1300RPM and the case fans are around 900-1000RPM does this seem like normal speeds for my case fans and cooler fans?
I don't know pretty upset right now and if this is what overclocking has become I will not be opting for K processors and special motherboards/cooling because its quite pathetic I can't even hit 4.5GHZ on liquid cooling. Hell even at stock my temps hit 60+ which is also pathetic.
Ontop of all of that my BIOS reads my voltage correct (1.275v) but my desktop, every program reads my voltage @ .5-1v (hwmonitor,cpuz,aida64 etc.) which is weird because ive never had this issue before. Like honestly I bought all liquid cooling to OC and keep things cool and quiet and while it's quiet my PC is hot as hell. I'm wondering if the fans arent going the proper speed? cause like I said at one point my case sounded like a jet taking off and I have never beena ble to get the fans to go that fast since I changed the settings.
I wonder if anyone can offer some insight and help me start clearing up these issues. Should I place the hybrid radiator as an outake in the rear instead of an intake in the front? How come my fans won't adjust speed when I adjust them in BIOS? how come my voltage isn't properly reading? and why the heck are my temps so damn high when I invested an extra $300 in my system just to properly overclock and keep it cool? It ticks me off when I see some kid with a 6600K and a 212 EVO and he manages to hit 4.7GHZ and keep temps under 70c it's like seriously? I've never had voltage reading issues and temps like this with such little overclock.
SYSTEM:
6700K @ Stock - 60C load
980TI hybrid 1480 - 53C load (radiator is set to intake from the front)
Phantek Evolv ATX (2 x 140mm intake SP fans in front, 1 x 140mm outtake in rear, 2 x 120mm SP fans upto push configuration outtake.)
2 x 2400mhz 8GB corsair LPX vengeance
1 x 500GB samsung SSD
1x 1TB WD black HDD
850w EVGA GQ PSU
EVGA Z170 FTW motherboard
Heres a picture of my case/configuration:
As you can see CPU radiator uptop in push config, 2 x 140mm in front sucking in, hybrid radiator mounted infront sucking in, 140mm in read pushing air out. All fans are SP series fans so it's not that. I was thinking of moving the GPU radiator to the REAR and having it push the air out and then have 3 x 120mm fans sucking in in the front. But I really like the way it looks right now and I'm not sure if that will be better considering I have so much air coming in but not really alot coming out. The fans on the top have barely any room to breathe because of the case. I feel like removing the rear 140mm will make temps even worse because the air will just sit inside the case.
SYSTEM:
1x 1TB WD black HDD
850w EVGA GQ PSU
