Trouble trying to get thermal display to work on this case...
NathanBWF
Case
As you can see from the link, there is a thermal display on the front of this case. There is a blue & white wire running from the front of the case with a 2 prong plug in that you plug into the power supply via a converter that is supplied with the case. There is another small cable in there with the thermal sensor at the end of it which I just having sitting in the case. Anyway, I can't get anything to come up on the display. There is also a red and black wire with some kind of plug on it that is too short to even reach the mobo that I don't know what it is. Ideas?
Pics:
Well I found part of my problem. The blue and white wires are actually for the lights on the front of the case, not the display. After pulling the front of the case off, I found out that that red and black wire is indeed from the display, but where the hell do I plug it in to give it power ?!?
EDIT: The head of that red and black wire is similar to the head of a pair of wires for your cpu fan, except this one only has 2 holes on it.
Well, I'm a jackass. There is another convertor for that plug that was sitting in the box that I must have overlooked. It's all good now.
