Signal:
Frequency 549000000 Hz Locked
Signal to Noise Ratio 37 dB
Power Level 2 dBmv
Channel ID 6
Frequency 29400000 Hz Ranged
Power Level 54 dBmV
Snap shot of logs:
2010-08-04 23:30:36 3-Critical R005.0 Started Unicast Maintenance Ranging - No Response received - T3 time-out
2010-08-04 23:30:32 3-Critical T002.0 SYNC Timing Synchronization failure - Failed to acquire FEC framing
2010-08-04 23:30:25 3-Critical R005.0 Started Unicast Maintenance Ranging - No Response received - T3 time-out
1970-01-01 00:01:11 3-Critical D001.0 DHCP FAILED - Discover sent, no offer received
1970-01-01 00:00:06 3-Critical R002.0 No Ranging Response received - T3 time-out
1970-01-01 00:08:28 4-Error D004.3 ToD request sent- No Response received
1970-01-01 00:08:23 3-Critical D002.0 DHCP FAILED - Request sent, No response
1970-01-01 00:08:16 3-Critical D001.0 DHCP FAILED - Discover sent, no offer received
1970-01-01 00:08:04 3-Critical R002.0 No Ranging Response received - T3 time-out
1970-01-01 00:07:57 3-Critical T001.0 SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
1970-01-01 00:07:42 3-Critical T002.0 SYNC Timing Synchronization failure - Failed to acquire FEC framing
1970-01-01 00:07:08 3-Critical D001.0 DHCP FAILED - Discover sent, no offer received
1970-01-01 00:04:41 3-Critical R002.0 No Ranging Response received - T3 time-out
1970-01-01 00:04:34 3-Critical D001.0 DHCP FAILED - Discover sent, no offer received
1970-01-01 00:01:05 3-Critical R002.0 No Ranging Response received - T3 time-out
1970-01-01 00:02:13 3-Critical T001.0 SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
1970-01-01 00:01:58 3-Critical T002.0 SYNC Timing Synchronization failure - Failed to acquire FEC framing
1970-01-01 00:01:54 3-Critical R005.0 Started Unicast Maintenance Ranging - No Response received - T3 time-out
1970-01-01 00:01:15 3-Critical D001.0 DHCP FAILED - Discover sent, no offer received
1970-01-01 00:00:05 3-Critical R002.0 No Ranging Response received - T3 time-out
2010-08-04 21:16:11 3-Critical D007.0 TFTP Failed - OUT OF ORDER packets
1970-01-01 00:05:30 4-Error D004.3 ToD request sent- No Response received
1970-01-01 00:05:02 3-Critical D007.0 TFTP Failed - OUT OF ORDER packets
1970-01-01 00:00:32 4-Error D004.3 ToD request sent- No Response received
1970-01-01 00:00:27 3-Critical D002.0 DHCP FAILED - Request sent, No response
1970-01-01 00:00:15 3-Critical D001.0 DHCP FAILED - Discover sent, no offer received
2010-08-02 00:27:47 3-Critical C206.0 DCC aborted unable to communicate on new upstream channel
2010-08-02 00:27:47 3-Critical R004.0 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 timeout
