Trouble installing my water cooling rig :(
Soulkeeper
6,732
155
i spilled water all over my video card because one of the hose clamps was bad
anyways i thought i had dryed it all up, but i didn't notice that some water had gotten inside the agp and pci slots
so basically my GF4 is now totally fryed
and the motherboard seems to have issues even with a good video card now
i get flickering on the desktop and in the bios
any ideas ??
you think my motherboard is shot too ?
Soulkeeper
6,732
155
This is not my day, i just got my pinky finger sucked into a 120mm fan
freakin sliced my finger up, i tellya
I hope something on the motherboard isn't fryed too
looks like water mighta gotten on the little resistors/capacitors around the agp slot
my fear is that the water, when given a charge, will leave a conductive residue even after it is dryed up
as a last resort i will probably totally uninstall the motherboard and look for any watermarks/residue over traces and such
Soulkeeper
6,732
155
but anyways, atleast I got my socket A waterblock modified to fit my P4 motherboard on the existing sp-94 mounts :)
and my temps are a good 10-15c lower without the pelts :)
Peter D
3,603
.. LOL, I think you need to be your more careful around computer hardware man.. :)
Soulkeeper
6,732
155
yeah i can't afford 2+ of everything
i'm kinda inbetween jobs so i'm broke
looks like my GF4 is gonna get replaced by the fx5200 that was in another computer
half the fps in UT... i tellya
Falloutboy
5,916
yes your dangerous....had a simlar problem the other night when I installed my water stuff....but I haridried the system for 15 min and let it dry why'll I was leak testing it for anymore leaks overnight. then I dodged a bullet when I forgot to tighten a hose clamp on my radiator and it was leaking all night while the system was running thanks goodness it wasn't anywhere near the mother board.
but all is good in water cooling land cool temps wicked fast overclock :D.
by the way how long did you wait after the water dried to reboot the system?
Zebo
39,398
19
I don't even use hose clamps an never had a problem in fact it's a royal PAIN to get the hoses off water blocks cause it's so tight.. wierd
What a fan powerful enough to suck in your fingers!!:p
Anyway don't worry, just set all wet componets out to dry about 48 hours before applying electicity to them and everything should be fine. My son srayed his COMP out with a water hose after I told him to use "the hose in the garage" ,meaning air hose to clean dust out, and after dying it booted perfect.
Soulkeeper
6,732
155
haha thanks
yeah i need to look for any water marks and clean them off with alcohol so that i am sure that the water didn't pick up any solder/resin deposits and create a connection anywhere (had this happen as a result of condensation in the past )
yeah the liquid was distilled water with water wetter added :)
but nomatter how clean the water was there was all kinds of dust/particles on the motherboard
Soulkeeper
6,732
155
anyways here are some Pi benchmarks with my prescott
2973 212 170 5:4 1.42v
1m 46s
2m 1:45s
3110 222 177 1.42v
1m 43s
2m 1:39s
3220 230 184 1.42v
1m 42s
2m 1:36s
3366 240 192 1.52v
1m 40s
2m 1:32s
3435 245 196 1.52v
1m 39s
2m 1:30s
3223 230 230 1:1 1.52v
1m 41s
2m 1:34s
Zebo
39,398
19
3435 245 196 1.52v
1m 39s
2m 1:30s
This is identical to my barton @2640. Both numbers.
Soulkeeper
6,732
155
i got 1026 3dmark03 with the replacement card
2.8e @ 3222 230 1:1
fx5200 128mb 324/420
1gig @ 230mhz 2-2-2-6
kinda a step down from the GF4 tho
joe2004
385
I may never go water until absolutely necessary. High maintenance
Really. So far none for me. Don't be discouraged by Soulkeeper, he is a #1 technology destructor around here. Sometimes it seems he is doing it for the pure fun and entertainment.
