Trouble installing K7T Pro audio
Byrd2a
I have been unable to install the audio on my K7T pro system. I loaded the Via 4 in 1 drivers, then installed the audio drivers from the installation CD. However, Windows 98 SE insists the audio device is not properly installed. After Windows attempts to install the audio, I get prompted to insert the Windows CD but Windows can not find numerous .ax files??? I downloaded the latest audio drivers from the Microstar site and that did not help.
Has anyone had a similar problem? Or perhaps someone has a suggestion.
Thanks
K7T Pro/T-bird 750/256MB Crucial Pc133/Maxtor 20GB/
I had a similiar problem. In the user guide or directions, I remember reading that you had to install the audio drivers in a specific sequence in realation to the rest of the drivers, 4 in 1, etc. I did it wrong and the audio would not work. I threw in a sound card, disabled the on board audio and called it a day.
