Trojan Ultra Thin
Night201
Just tried a sample one last night. I have 2 left. I like them much better than the Ultra Pleasure ones I use. I think I'll have to switch, but I don't know if they are out yet. I think the ones out now are .06mm thick. I'll have to do some research. If they are out, I'll have to kick myself for just buying that 36-pack of the UP ones.
Has anyone else tried this one?
I know this is probably close to a block, so try to keep it clean.
I wonder who the first to state that the best pleasure is no condom...well, duh!
i never really felt safe using thin condoms...i usually get enough pleasure from regular condons or even the female pleasure ones...thin = really that good? maybe i try one...lmfao, with my luck ill be having a baby in 9mos >_<
Originally posted by: JulesMaximus
I never use condoms.
You'd have to have sex in order to use a condom.
I kid, I kid!
Originally posted by: Journer
Originally posted by: D1gger
A 36 pack - that would be a six year supply for me!
lmfao...ive bought like 4 36ers in the past 3months 😀
lots of sex FTW!!
Shens. That's like, 144 condoms, which is like, 4-5 times a day.
Originally posted by: Night201
Just tried a sample one last night. I have 2 left. I like them much better than the Ultra Pleasure ones I use. I think I'll have to switch, but I don't know if they are out yet. I think the ones out now are .06mm thick. I'll have to do some research. If they are out, I'll have to kick myself for just buying that 36-pack of the UP ones. q]
You afraid your gonna get your hand pregnant or catch somethign from it?
Do they come in XXXL?
I thought they really test these condoms. The stretch them out or they fill them with water to see if they can hold. If so the should be safe, unless your name is C.N
Why? You planning on covering your arm with one?
Why would you be asking?
Condoms are one-size fits all. :roll:
I have a hard time finding condoms my size
I don't think it's just water. IIRC, they fill them with electrolytes and then test to see if an electric current can penetrate them (through micorscopic holes).
Er 😕...
Boldy half inch?
