- Nov 29, 2000
- 99
- 0
- 0
Downloaded a ?no cd? patch from KazaaLite and ran it.
Apparently it was a Trojan of some kind.
My virus scanner caught and disabled it.
But not before it made changes to my system, apparently.
It installed something called ?rohfemmoc.exe?.
I restarted the machine thinking the virus scanner had done its job and Windows took a bit longer than normal to boot.
A window pops up saying that ?rohfemmoc.exe? can?t be found.
Then I discover that I can?t launch any programs.
?Windows cannot find XXX?? dialogue box pops up when I try.
Not from the shortcuts on the desktop or from the Program Files folder.
So, I do some looking and find a prefetch file with the ?rohfemmoc.exe? and delete that.
Then I do a manual search of the registry and delete any entries with that name.
One entry was listed under a string with ?Shell? in the line and had ?explorer? & ?rohfemmoc.exe? in it, so I deleted the ?rohfemmoc.exe? portion.
Also located ?rohfemmoc.exe? in the startup/boot file and disabled it there.
Reboot and no more ?rohfemmoc.exe? but I still can?t launch programs without the ?Windows cannot find XXX?? dialogue box.
So I dig around a bit more and discover that I *can* launch programs if I right click, go to ?run as? and uncheck the ?Protect computer?? box.
Most everything runs fine.
But this doesn?t bode well.
I say most because after I get the Help program running I discover that some links in it to OS files don?t work.
It can?t find the MSINFO32 file. An ?error 2? window pops up.
And it won?t launch some of the other help tools like Disk Cleanup and Backup.
I get a ?This program will not start?? window.
The upside is my computer is still running and I haven?t had to reinstall the OS.
The downside is that I don?t have any restore points to go back to.
One odd thing.
When I was in the Help program and clicked on the Disk Cleanup link, the first thing under notes is a line that says ?XOXOX??
Hugs and kisses from Microsoft?
Hmmmm? lol
Any help would be greatly appreciated.
brett
One odd thing.
Hmmmm? lol
brett
