- Jun 30, 2004
- 16,754
- 2,107
- 126
First question.
I'm modding two twin high-end cases released around 2005 or 2007. For reasons of cable management, I've only connected two of the four available USB 2.0 ports of the case-front. There are four rear I/O-panel USB 2.0 ports and four USB 3 ports. I've added two USB 3 ports to the front of the case on my own, and two more to a PCIE plate at the rear.
Is there any problem using the downward-compatible USB 3 ports for USB 2 devices? I thought I'd seen some wording online that tried to discourage it -- for whatever reason. I don't see a problem there. I had done it until last year with a USB3 connection to my KVM switch so I could use a single keyboard for three systems. The KVM switch operated perfectly from 2016 until 2021, when ;I removed it from the equation to troubleshoot what I soon discovered was a blown USB controller on the motherboard due to a static charge accident (the Vaping Pen accident). There are now only two computers, and I'm just using separate keyboards or a Logitech wireless that can be redeployed in a few seconds.
Second question. Case wiring comes with a front-panel audio (green/pink 3.5mm stereo) wire with an HD Audio motherboard plug, followed by an AC97 plug and terminating with single-wire connectors for Azalia. Since these latter two plugs or plug-groups will never be used, it seemed to me that one could just cut the wires and insulate them. In fact, I already did that -- the latter two plugs seem to be simply extensions of the wires first entering the HD Audio plug.
Anything wrong with that?
I'm trying to prevent a clutter of unnecessary connectors and wires in my case.
OOPS! One more query to demonstrate my lack of confidence (I'm supposed to be an "old hand" at this . . . ) . . So -- third question . . .
The front-panel motherboard pinouts include connections for a 3-pin power-LED cable (two conductors), and a "PLED" 2-pin pair. I would think, if you wanted two LEDs to go on when the computer is switched on, you could connect a plug of each type to the pinouts.
Anything wrong with that? LED power draws are negligible. If no answers here, I'm going to try it anyway.
