tj_jokestar
I just got a xfx 6870 and was wondering if its possible for a third monitor (using 2 dvi's and 1 hdmi)
thanks trevor
thanks trevor
AFAIK, only Sapphire has a card capable of this. Flex edition.I just got a xfx 6870 and was wondering if its possible for a third monitor (using 2 dvi's and 1 hdmi)
thanks trevor
Make sure you get the active displayport adapter, so it will be around $30. If you see a super cheap adapter, it's probably not an active adapter. Note that there are more expensive active displayport adapters for like $100, but those are meant for dual-link connections and use a separate power source.
The $30 adapter does not need its own power source, it's active display port, and it's single link. Should be fine for resolutions up to around 1920x1200.
you plan to use eyefinity and I want to avoid tearing you may need to use the display port connections or 3 dvi connection rather than mixed...
can you have 3 display port connections for the video card and 3 dvi connections on a monitor and resolve the tearing issue? or do connections on each end have to be the same? Maybe someone else can answer that question?
"Tearing" is a specific term of art for displays that describes a specific situation, but I'm not sure how you are using that word or if you mean it in the traditional sense. Typically I've heard "tearing" used to describe a situation with only one monitor, but how are you using it here?
What do you mean about using 3 dvi connections rather than mixed? On a typical video card that supports eyefinity, you can't use more than two ports simultaneously if you aren't using a displayport. So, if you want to use 3 displays simultaneously, you need to use displayport. That can be achieved in several ways: 1) get a displayport adapter to use a standard DVI monitor, 2) get a displayport monitor and plug it directly to the displayport of the video card, or 3) get a videocard that has a built-in displayport adapater inside of it so that the displayport info is output to a DVI port on the video card so that the video card provides simultaneous output to three DVI ports (there is a name for this type of card, the flex edition. However, I don't see any value for it, because it will cost more to get a flex edition than it would to just get a typical card and buy a separate displayport adapter to effectively convert the typical card to a wanna-be flex edition).
