trimming goatee???? HELP!!
Alex
6,995
lol so spontaneously a couple weeks ago i decide to grow a goatee ... its all good until i start realising that its goin from smooth to like white-trash pretty quickly :Q
thing is im no expert (duh) and don't feel like goin all the way to the barber to trim it... umm... anyone care to elucidate plz?
Fausto
26,521
I just use the longest of the four guides for the clippers I use to cut my hair. A decent set shouldn't run you any more than $20-40.
Fausto
Alex
6,995
hmm trivial as it may seem i haven't thought of that pyonir... :p
but isn't there a manual way?
pyonir
40,855
319
Fausto
i got my trimmer for $20. bunch of attachments too. but it is a beard trimmer, not a hair trimmer, so it isn't very wide.
pyonir
40,855
319
if you want to use scissors...go right ahead. i never will. why make it a pain the ass when a $20 clipper will do the job in less than 5 mins?
cavingjan
1,719
When I had my goatee, I kept it nice and short and simply used a decent pair of scissors (for cutting hair) and a comb. It usually took 5 minutes. My beard trimmer sometimes chewed the ends up badly.
Alex
6,995
pyonir... totally... but like i need a short-term solution for tonight.. :) neways thx for the advice...
amish... well... um... perhaps :p
pyonir
40,855
319
you could just have your cat lick it off. i mean it is only peach fuzz i am sure.
Fausto
26,521
Originally posted by: franguinho
fausto dude you cut your own hair?? :Q
Sure, have been for years. I have really thick hair so it doesn't look too goofy cut short. I just run the clippers with the longer guard all over my head and then switch to a shorter guard and trim the sides and back (I use a small mirror to do the back of my head and neck). Takes about 20 min and looks decent. I do a lot of cycling and I stay a lot cooler in the summer down here with my hair really short.
Fausto
Alex
6,995
iamme... lol my bad! :p if it makes ya feel any better i don't grow much hair between mustache and chin either... its genetic... neither does my dad... neways a goatee afaik is just chin... the full thing like cashman's avatar is a 'van ***' iirc...
fausto nice! :) i have a friend who does that... like i actually thought you like cut it for real... i don't even think thats possible... :confused:
