Trillian help?
Nocturnal
18,927
anyone familiar with trillian?
is there anyone who can tell me how i can move my contact groups to where i want them to be, or is that not possible?
help?
NutBucket
27,127
616
Do you mean reorganizing the groups? If that's what you're after, you need to show all offline contacts. Then you can drag the individual contacts between the different groups.
Rallispec
12,375
10
you just have to make sure you disable the 'offline contacts' folder or it wont let you move names around.
