trillian help
adamRB12
Banned
i downloaded trillian w/ azureas and the file wouldnt open so i tried to delete it and this poped up...
-Error deleting File Or Folder-
X cannot delete trillian-v3[1].1.exe: it is being used by another person or program. close any programs that might be using the file and try again.--------------
do u have any idea how i could delete this?
That's the pro version anyways, if you have a pro license than log into the Trillian site and download it from there otherwise be gone with you!
i didnt have azureus running when i tried 2 delete it, but it still wouldnt let me delete. Is there any other ways?
Sounds like something still has a file lock on it. You might try running task manager and making sure the azureus processes arent still running (dont forget java.exe).
If you still cant delete it try logging off and back on so all your user processes are killed.
i tried the reboot then delete and i tried ending processes in task manager, but neither way workd. i heard u can delete things using the DOS menu but i dont know how to use it.
Boot up in safe mode then. If you rebooted that should have worked, unless you set azureus to load up on startup.
Originally posted by: adamRB12
dude, im tryin to delete it not pirate it. n if its free anyway whatz the prob.
The Pro version isn't free. The Basic version is. Anyways, if it's "free" as you say, why didn't you just download it from the Cerulean Studio's site?:roll:
The free version is great, anyways. Just reboot and go to the boot options, Safemode will be one of your options. It's pretty straight forward, just watch the screen.
the pro version is actually a bit more bloated, since it has a video/audio plugin to load. make sure azureus is off on startup, then try deleting it. if that doesn't work, if you didn't remove it from azureus, you can right click -> remove and delete both torrent and data.
