Trigonometry help.
Braznor
4,771
435
Hi,
I work in the IT department of a company full of engineers, but I'm not an engineer myself. I'm currently employed in the company as a consultant for SAP ERP currently used by my organization. Since I joined this company, I have developed an interest in learning mathematics and science (as a hobby, not for work). Right now I'm learning trigonometry using Michael Corral Trigonometry textbook. One of the exercises in the book stumps me very much and I have been hunting for a solution to it.
The book exercise says r = 0.944 in the solutions section. However I'm not getting how to derive the same. Here is the exercise as described in the text book :
1.3.25 A manufacturer needs to place ten identical ball bearings against the inner side of a circular container such that each ball bearing touches two other ball bearings, as in the picture on the right. The (inner) radius of the container is 44 cm.
(a) Find the common radius r of the ball bearings.
(b) The manufacturer needs to place a circular ring\\inside the container. What is the largest possible (outer) radius of the ring such that it is not on top\\of the ball bearings and its base is level with the\\base of the container?
I know this is elementary and basic. But it has been long since I have practiced mathematics since school and college. By the way, I'm 43 years old and I'm ashamed of being a maths brainlet. Please be assured this is not my school homework or anything.
Please help.
sdifox
101,220
18,229
Decagon with each of the point being the center of each circle.
snoopy7548
8,306
5,385
As an engineer, I find the best way to solve problems like this is to look at the answers in the back of the book. :p
Reactions: Red Squirrel
sdifox
101,220
18,229
Do you even google? I had to look up the name of a ten sided polygon even know I know it is supposed to be deca for ten and gon lol
sdifox
101,220
18,229
Please help!
The problem is eating my head......
wtf, I already gave you a hint. you should be able to figure it out from there. Trig questions are about perspective more than anything else.
SKORPI0
18,503
2,430
deadlyapp
6,685
752
Hi,
Please help.
I think someone already posted some details, but you need to think about the circle that is inscribed by the center of all the bearings. The radius of that smaller circle is 4-r and the circumference of that circle can be derived through that and the known outer circumference of the outer race.
Reactions: highland145
35,614
Place ten balls known to be too large in the bearing . They will grind themselves down to the correct size. Once the bearing stops making noise, measure the balls.
Braznor
4,771
435
Thank You,
I'm trying to work it out your way.
BarkingGhostar
8,410
1,617
You jackass! :p That's the difference between those that can and those that do. Dullard has the answer, which I got immediately, but that's another story. Look at the answers in the back of the book ...
snoopy7548
8,306
5,385
At least I'm not the management type (those that can't)... just get others to do it for you! :D
But I hear it pays pretty well...
BarkingGhostar
8,410
1,617
A manager I had twenty years ago said, "I don't need to know how to do it (meaning my job), as his job was to manage those that did know." As he said this I remembered this guy from an ATM class teaching us about Asynchronous Mode Transport and telling us about the smoke and mirrors we would get into later--he was talking about virtual circuits in ATM. But I beg to differ on your front. As an engineer it should be automatic to solve the problem by not going to the other guy (who wrote the answer in a book) unless it is standard/reference data. That problem wasn't hard, just cluttered to make it look hard.
Spacehead
13,067
9,858
About 15-20 years ago the boss got pissed at me for using one of the computers to figure out some roll dimension for work. So since then i'll sit at my bench & figure stuff with pencil & paper & sometimes take way longer than just going & using software.
I do like being able to figure things on my own but there are some things i just haven't found formulas for & i need to have someone figure for me on the computer. I've never used AutoCad so someone else has to do it for me.
