Trig Help...
jacob0401
cos 2x = 2 cos x
I'm supposed to find all the exact solutions(2 of them), algebraically, in radians.
This has to do with double angle identities, but I can't get it to a point where I can factor.
Any help is appreciated...
btw... cos 2x = 1-2sin^2(x) or 2cos^2(x)-1 or cos^2(x)-sin^2(x)
Yeah I can get it down to quadratic, but that gives me a decimal or root answer and it specifies radian measure.
Originally posted by: UncleWai
memorize the unit circle, calculator is evil for trig.
i have memorized it...but i can't even reduce it to the point where i can solve for cos/sin/tan...
If y = cos(x); you get:
2y^2 - 1 = y, or equivalently:
2y^2 - y - 1 = 0, which gives
y = 1 or y = -1/2
I posted when dighn had an "answer"
you wrote£¼"but that gives me a decimal or root answer and it specifies radian measure. "
So I thought you were using a calculator to find what X IS 😱
And when solving that I get y = +-(sqrt(3)+1)/2..see if you can convert that to polar after taking cos^-1 of that..
Or you might just be able to leave it as cos^-1((sqrt(3)+1)/2)
yes, it's 2y; doing math after midnight is never a good thing 🙂
btw, cos^(-1) of ((sqrt(3)+1)/2) does not exist because ((sqrt(3)+1)/2) > 1 (this is because cos takes values in [-1,1] only)
the answer should be cos^(-1) of ((-sqrt(3)+1)/2) (there are more solutions using the periodicity of cos, and also cos(-y) = cos y; probably you will need to find the answers in [0,2*pi) only, because of the periodicity)
check the place of the - sign again
edit: typo, it's too early for me to think
