Trifire 7970 order in case
cbrunny
I've just picked up a third used 7970 for some trifire gaming in 1080p eyefinity. Wondering which order would be best to arrange them. The three:
XFX Double dissipation - two slot
PowerColor reference cooler - two slot
Asus Direct CU II - three slot.
I'm thinking Asus, XFX, PC from top to bottom. Thoughts?
Case is corsair air 540 with 2 x 120mm corsair SP fans blowing direct onto the GPUs from front, one additional intake in front - a cheap garbage fan, two x 140mm corsair AF fans on the top for exhaust, and one additional exhause case fan out the back.
Thanks in advance
To make deduction (answers) more accurate, tell us what m/b you use , so to determine where that 3 slot card would fit best.
