Hi everybody,
I'm trying to assemble a new system, well, and I can't get it to the bios. I'm running out of ideas, so let me walk you through what I've tried.
Material:
Rosewill case with 400W PSU
AMD A64 2.6 CPU
500GB WD HDD
MB FOXCONN A7GM-S AM2+ 780G RT
2GB skill RAM
The problem:
I assembled everything following MB manual closely. I power the system on: the power seems to go on, then off, then on, then off.
I first checked the PSU. Following the PSU manufacturer rep recommendation over the phone, I use the paper clip and started it. It works. Smoothly. I think, and so does he, that it must be the MB.
I returned the MB to newegg (where I bought it). They say it's DOA, then return me another one. I get the second MB, same problem.
Granted Foxconn isn't the most well known company, I decide to buy-return a PSU at a large store. Replace the PSU, same result. Doesn't seem to be the PSU, so at this point I'm thinking I'm just not lucky and got two DOA MB.
I'm obvious a little tired of foxconn, so I cancel the order and get an ASUS instead:
MB ASUS M3A78-EM AM2+ 780G/SB700 RT (onboard video)
and plug everything in.
Now, it's not really shutting down (the green Power light on the MB stays on), but the screen stays blank and I can hear the HD, heatsink and case fans slow down, accelerate, slow down, etc. If I plug-in the blu-ray drive, it does the same thing too. Basically the same problem... or so it seems.
Any ideas? I'm tired of returning parts and everything, this whole process has taken well over 3 weeks.
Thank you in advance...
Material:
AMD A64 2.6 CPU
500GB WD HDD
2GB skill RAM
The problem:
