Tried burning a cd and the buffer read 0% not 100% then failed.
datdamkid
1,540
Well, I tried burning several CD's and they all failed then I noticed that my buffer read 0%. Then i went into deviece manager to see what was wrong and try to update drivers. And what I had found is that my CDRW (I have 2 of them) are saying that they are SCSI in the device manager. I tried rolling back the drives and even tried updateing, but I didn't get any luck. Has anyone had a problem like this and or can help me out I would greatly Appreciate it. Thanks
Thanks again
Palak
Anubis
78,712
427
tbqhwy.com
uninstall them from the device manager and reboot
windows shoudl autodetect them and install the driver
Sid59
11,879
could be serveral things. things i've noted in the past with this.
1. could be an OS update. i once installed a hotfix and it messed with my burner buffer
2. virus
3. some program hogging 100% resources
datdamkid
1,540
do you think it might be because i only have 256megs of ram? I think I need another 256 chip....
geno
25,074
4
256 is enough and shouldn't cause problems like that
datdamkid
1,540
yes, before it use to read 100% now after i formated and reinstalled it stopped working after a couple of burns. I got a few successful but then i rebooted for somethign and it stopped...and for some reason they are reading scsi why they are not.
Iron Woode
31,312
12,825
The program i am using is NERO 6 Ultra
What Burner are you using?
Sounds like buffer underrun protection is turned off or you don't have buffer underrun protection on that drive.
VirtualLarry
56,587
10,225
Let me guess - you have a Via chipset motherboard, and installed the newest Via drivers (All of them) when you re-installed? If this is the case, I suggest backing up your important data, and re-installing again, this time, don't install the Via IDE drivers.
Alternately, you could attempt to uninstall them or manual force upgrade the drivers to the WinXP default built-in ones. I would still make a backup before messing with the disk-controller drivers though.
