I have AT&T U-Verse internet with a 2WIRE 3801HGV router. This was just updated because my original equipment finally failed. I had no issues getting any of my computer or devices to connect save one... a Compaq laptop with Windows Vista on it. At first the issue was I was getting the local only/limited connection issue but now the laptop won't even go that far after I updated Windows and the drivers for the networking devices. I've tried everything I can think of such as adding the network manually to the laptop etc... I spent over two hours with AT&T support who were certain that the internal wifi card has failed but the laptop will connect to other wifi networks and even to the home network IF I remove all security. I'm at my wits end here and have scoured the internet looking for ideas to no avail. I've got like 6 hours into this thing already. Can someone lend a hand? I'll post the ipconfig below, thanks in advance.
Windows IP Configuration Host Name . . . . . . . . . . . . : lindsey-PC Primary Dns Suffix . . . . . . . : Node Type . . . . . . . . . . . . : Broadcast IP Routing Enabled. . . . . . . . : No WINS Proxy Enabled. . . . . . . . : No Ethernet adapter Local Area Connection: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : gateway.2wire.net Description . . . . . . . . . . . : NVIDIA nForce 10/100/1000 Mbps Netw Controller Physical Address. . . . . . . . . : 00-1F-16-71-22-99 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Wireless LAN adapter Wireless Network Connection: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : gateway.2wire.net Description . . . . . . . . . . . : Atheros AR5007 802.11b/g WiFi Adapt Physical Address. . . . . . . . . : 00-24-2B-C8-17-59 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes
