Originally posted by: amnesiac
Better speakers.
5-ch amp or 2 separate amps to run speakers/sub
An equalizer does wonders.
Better security system on your car so some foo' doesn't jack your gear.
What kind of car is this going in?
Originally posted by: Walleye
how much the whole set gonna cost me? im going for bargain here...
You can give your existing system a nice lift w/ $300-400:Originally posted by: Walleye
You want to put a car PC and a system in a car on a budget/bargain? That defies the point.
1) Set of component speakers for front (Focal, Diamond Audio, infinity) - $150
2) Nice 2 channel amp (Orion, Phoenix Gold, PPI) - $130
Then:
3) Quality head (Pioneer, Premier, Alpine, Clarion) - $200-300
4) Quality Sub driver (Alumapro, Focal, JL, Infinity) - $150
5) Custom built enclosure (essential, don't pick up a cheap bandpass box) - $300-400
6) Sub amp (orion, pheonix gold, PPI) - $200
i figure i can do that for less than 200 if i get the components from someone... he's gonna give me a lappy with a slim dvdrom, a 20 gig hard drive, and some other stuff. i'll buy one of those 12 v power supplys, one of those mini-itx computers, then i'll get a lcd display, like 5 inch, off hot deals or something for like 50... it'll be great. then it'll be a carputer
and i could run linux on it, and play dvd's, cd's, and mp3's. it'd be great![]()
Well nm then. The car audio part will kill you.
That's the point, moron. Not all amps run CLEANLY within spec. Get a sh!tty amp, and it will clip well before its rating. Clean power is the most underrated link in the setup.Amp brand matters not 1 bit except in features and reliability. They all make power, equally well as long as there run within spec.
It's still got plenty of info and people do help. There are plenty of post nazi's there though, I'll give you that.Sounddomain has more asshats then any forum I have EVAR been to. I would not recommend it.
Since he's not going for a HQ setup, I was referring to polyglasses. Go here.. They're a buck 70, though. I've seen 'em at my dealer, open box (mint) for ~ $150. Sure you can ebay a better deal.And Phir, show me Focals for 150
Here and here. I wasn't talking about 500WX2, more like 75-150WX2. This is a fronts, beginner/HQ bargain amp.PG [for] 200
Originally posted by: Ophir<br
And shockwave, try to settle down before you post.
well, like i said, the speakers in the corolla are good speakers, aftermarkets. good pro install job on them too. apparently the former owner was a dipsh1t, and forgot when he sold it to the dealer that he had aftermarket speakers in theregood thing the dealer didnt check it either
so that cuts down my cost significantly.
what's a head?
