Trees, their roots and pools
RPD
5,109
600
Is there any legal precedence for a pool owner who's pool may be in jeopardy from a neighbors tree roots?
Examples, existing pool, neighbor plants tree that will grow very large and roots will eventually damage the pool.
Or existing trees not quite large yet, neighbor adds pool. Eventually trees damage pool.
In either example is someone on the hook for the damages the roots could end up doing to a pool?
GasX
29,033
Yes, you are on the hook when you wake up one morning and your pool has drained and popped out of the ground.
Mar 10, 2005
14,647
in mass, tree branches hanging over a property line are fair game for you to chop, and i think roots would be the same. i think if a neighbor's tree falls onto your property, he's on the hook for it. ymmv.
also, consider that excavating adjacent to the pool without damaging it is a nightmare by itself.
RPD
5,109
600
I'm not looking for advice on how to avoid the issue. I'm asking about if the issue occurs.
Obviously if you own the pool and the damage happens it's going to suck for you regardless of the legalities involved (if any).
GasX
29,033
From personal experience, I know that if your neighbor's tree has a branch over your roof and it snaps and puts a hole in your roof, it goes on your homeowners insurance. However, if the branch was dead and he did nothing about it, then it becomes his liability. I imagine live roots work the same way and you are SOL unless the tree dies and dead roots destroy your pool - which is... unlikely
Newbian
24,779
882
There is a easy fix to it and that would be to burn said neighbors trees to prevent this ahead of time. ;)
Bubbaleone
1,803
4
Just cut a trench along your property line once every ~5 years.
This^
Ditch Witch property line every five years...problem never occurs.
RPD
5,109
600
This^
Correct, however I'm not interested in how to avoid the problem (already knew how), merely asking where the chips lie if one of the examples occurs.
drebo
7,034
If they neighbor is nice, and is clearly at fault, he might be willing to split some of the cost with you.
My landlord had a bush whose root ball found its way into a neighbor's drain pipe. Pretty sure he split the cost of replacing the pipe with them.
sdifox
100,505
17,956
depends on where you live I would think.
gorcorps
aka Brandon
Jul 18, 2004
30,741
456
Yes, we get that, but part of explaining the legalities of it is that you can prevent it. It's your property line and you have the legal right to dig up the roots and chop them off. It's up to you to do so or not. If you do not do such a thing and the roots spread and ruin your pool, that's on you because it's the risk of pool ownership. The owner of the tree can't control where the roots go, and it's up to the pool owner to take care of the pool structure.
RPD
5,109
600
All correct, however how often are our laws and logic used together?
edro
24,326
68
I highly doubt it.
They are not responsible for damage to your property for falling limbs.
I would guess it would be the same thing for driving roots.
It is obviously not intentional.
weadjust
636
Spike 80DF is a solid powdery substance that must be mixed with water before being applied to the soil around plants. It is absorbed by nearby roots and kills plants by interfering with photosynthesis. A tree that's been targeted with the herbicide may drop its leaves, regrow them and shed them again until its roots die.
