Tray on my CDRW won't move.. HELP!!
earth4x
53
Hi guys
I was messing around my comp one day and I realized my CDRW tray was opened a little bit.. tried opening it by pressing on the button but it wouldn't do anything.. I then tried to put a pin the emergency hole.. no luck.. it wouldn't matter how hard I would press down.. it wouldn't move
is there anything else I can do??
jackschmittusa
5,972
Pull the drive and take the cover off. Sounds like something is jammed. Should be able to see what with it open.
