Travelling with Vonage
Apr 17, 2005
13,465
My parents are gonna be travelling quite a bit in the near future. Do you guys have any ideas as to how they could take their vonage with them? My dad has the unlimited world plan and he needs to stay in touch with my grandmother cause she is going thru some medical treatments. I figure they would need a wired connection to the vonage box right? Is there some sort of PC client for vonage? Thanks.
zerogear
5,611
9
Why not just Skype + Skype world subscription? But I believe if they take their Vonage box with them, they can hook up any phone then the vonage box to the internet, and it should work.
Apr 17, 2005
13,465
well they're travelling a week at a time, so they just wanna try and use the vonage sub and not sign up for somethng else.
pm
Elite Member Mobile Devices
Jan 25, 2000
7,419
22
I've done this before. I took my Vonage box and my CallVantage box with me on two separate trips.
The trick with Vonage tends to be that it wants access on a bunch of ports. So you need to port forward stuff - or stick the Vonage box in front of the router. The symptom of not doing this was that the call would either sound really bad, or initially sound good and then abruptly terminate after a couple of minutes.
So, my answer is that you can do this if you can plug the Vonage box directly into the internet connection of wherever your parents will be. So if it's a house or something, just do modem -> Vonage box -> router. If it absolutely needs to be behind a router (like a hotel's connection) then it may work but you will likely have problems. Vonage uses a lot of devices and maybe other ones work better than the Dlink one that I was using.
One thing that I will say is that Vonage technical support is no help at all if you have issues during international travel with it. Their very prompt and unequivocal answer is "we don't support traveling outside of the US with our telephone adapters." which is a reasonable enough answer, but it's not very helpful when they won't even help to troubleshoot it at all.
