Agent11
I own a 88 Argosy Airstream trailer, the water heater has a pvc drain plug that was leaking hot water. I took the plug out and put some thread tape on it then screwed it back in.
The problem was that as I screwed it in it never got tight, and the head came right off. The Plug was hollow and so now I have what is essentially a very thin, short pvc pipe busted off in this fitting for the drain plug.
How the hell do I get it out?
