pandemonium
Hey guys. Appreciate anyone that can offer some input for my problem.
I just changed my transmission oil out after ~25k from Honda MTF to Honda MTF on my '06 Acura RSX (total miles 92k) since the colder weather was really starting to get the notchiness going. I didn't open the transmission case, shifter levels, or mess with the clutch what-so-ever. All I did was drain the fluid out for new. I even had a level across the most level place I could find on the car - upper sway bar, lol.
During my commute to work second gear started sputtering with a "card in spokes" type sound that would increase with speed (the 4th or 5th time I hit second gear during the commute). The sound is only when second gear is engaged; once the clutch is pressed it's gone and 1,3,4,5,6, and R have no problems at all. My guess is that some fragment of metal that was perfectly resting prior to the change became loose and found its way onto my second gear synchro or a bearing. My google foo found this thread about the input shaft bearing being the culprit but I'm hoping that's not the case since my problem is specific to 2nd gear.
I went to both a transmission shop and the Acura dealer to get some input and both left me with very little options. I was told that a fluid flush is the only cheap option prior to opening the transmission and diagnosing the problem. Thing is, this is just a silly that I'm getting an odd sound coming from 2nd gear (with no apparent adverse effects to function) and that all I did was drain the transmission oil, and refill with new Honda MTF with a leveled car up to the point that it started to come out the fill hole (which was about 1.8quarts - the required amount from service manual). My luck sucks. :/
I'm going to try another drain and fill with new fluid again to see if it'll fix the problem; running through the gears at the same time to hopefully knock whatever loose. Acura wanted $110 to do it...lol.
Any transmissions experts out there that can provide some input? Appreciate your time!
