- Apr 20, 2009
- 3,793
- 1
- 81
Just recently performed a transmission fluid and filter change on a 2000 Silverado with a 4L60 transmission. Dropped the pan, and let it drain over night. Installed new filter, gasket, and re-installed the pan. Added fluid based on the Haynes manual (and several other sites) suggested fluid and filter change recommending 5 quarts. I first added 4 qts, let the engine run several minutes, checked and the fluid registered low. Added the additional quart, and checked, and the fluid level read fine.
Test drove the car, and experienced a high pitched whine in 1st and 2nd, though shifting seemed normal otherwise. Parked the truck for the night, and checked the fluid level in the morning. It was literally 1.5 to 2 inches above the full hot line (when cold). WTF?
At the advice of other forums, I grabbed some poly tubing and pumped the extra fluid out of the dipstick/fill hole. After several iterations of doing this, I've removed approximately 2.5 quarts of fluid. That means, of the 5 quarts recommended, I somehow am listed at full despite only adding half the suggested amount.
At this point, I am concerned that fluid may not be pumping out of the reservoir (if that's possible), and that perhaps the fluid is not moving through the radiator, etc. as it should be to be cooled. Thus far, my test drives have been less than 5 miles, but I am looking at a 60 mile round trip commute tomorrow to pick up some furniture. I don't want to drive this thing if I am going to risk killing the transmission.
My only guess is the new trans fluid filter is not drawing in fluid, but that's all I got.
An easy way to check, I suppose, is to remove the cooler line from the upper radiator connection and run the engine for a few seconds to see if it flows through the tube. Or, more simply, perhaps just check the temp of the transcooler lines... if the line coming from the radiator is cooler than the line coming from the trans, then fluid is flowing through the radiator.
TLDNR:
Performed trans filter / fluid change.
Haynes manual calls for 5 qts after dropping the pan.
Mine took 2.5 quarts (removed 2.5 after checking the following day that it was way over filled)
The question - How is it possible that I am "full" with only 2.5 quarts when the manual and other forums suggest the correct amount is 5 quarts?
Thanks in advance for anything you can contribute on the matter.
TLDNR:
