transfering HDD's??
DF-1
Hello guys, I currently have a system thats a:
i7 920
asus p6t,
gtx 285
samsung f3 1tb + WDCB 500gig (the western digital has all my data, and OS)
how do I transfer my HDD's with all their data into my new system that will be a 2600k, gtx 580, ga-z68x-ud3p-b3?
Do i go uninstalling in Device manager unplug them, and install new drivers/chipsets in the new one?
Do I not uninstall anything, unplug and install the new ones?
Is this even possible to do? how should I do it?
I really don't want to format and reinstall everything.
Thanks! :D
Paperdoc
2,523
388
What you want to do is actually relatively simple. BUT there is one important limitation, so we'll deal with that first.
You can NOT expect the OS already installed on the WD 500 GB unit to work in your new system. Whenever an OS is installed on a hard drive, it is customized for the set of hardware (the computer) the HDD is installed in. The installation process does an inventory of all the devices in the computer (and there are usually 30 to 50, many of them components of the mobo itself) and ensures that all the drivers for them are installed as part of the OS. If you then attempt to install that HDD in a different machine and BOOT from it, there are two very similar problems: the new machine has devices for which the HDD does not have the correct drivers, and the HDD does have and load drivers for devices that are not present in the new machine. There is a process called "Repair Install" that can be run on the old drive when first installed in the new machine, but you need the OS Install disk for that OS version. It does not always work, but often does. If corrects all the driver mismatches and then the OS is re-customized to the new machine's hardware set. If you need to do it this way, look up "Repair Install" for Windows.
HOWEVER, the really simple way to move up to a new machine is to be sure that the new machine has its OWN NEW HDD, and you install a new OS on that. AFTER that is done and working you can shut down and install the HDD from the old machine into the new one and just have it used as a data storage device that you do NOT try to boot from. In this situation ALL of the contents of your old HDD is fully available to you. There is no need to Uninstall anything in Device Manager on the old machine.
You should be aware, however, that application software installed on the old HDD will NOT be considered installed on the new one. Installing an application involves making custom entries in the Registry of the machine. An application residing on the old HDD does NOT have any corresponding Registry entries in the new OS on the new machine's HDD. Your best route here is to re-install all your application software on the new machine on its C: drive, and then you can use all the data files and documents from the old HDD. To do this you may well need to check with the publishers of your app software to see how you can install it a second time on a new machine. No doubt they will need some assurance that it cannot continue to be used on the old machine at the same time.
DF-1
I can't really afford to buy a HDD/SSD right now, and you said that the applications wouldn't work on a new one with a new install of the OS anyway.
the repair option isn't a 100% fix? I really need to know as ill be 12hours of flight away from my current PC, and won't have anything to work with.
DF-1
I found something on tom's hardware that talks about sysprep, I didn't understand all the instructions but it seems to be exactly what I need, upgrading with my HDD's to a new machine.
is this a good idea? does it do what i need? if so, how do i do it?
can anyone explain it to me better than in tom's hardware, i got confused with his post, to run the .exe directly? it says something else about cmd and putting: "sysprep /generalize /oobe /shutdown" in??
Thanks! :)
EDIT: found all my answers I think, sysprep apparently does exactly what i need
http://www.sevenforums.com/tutorials/135077-windows-7-installation-transfer-new-computer.html
^ is the guide im going to follow, thanks for all the help!
edit #2: going through the comments on the sevenforum, it seems like sysprep also does not have a 100% chance to work... i am so stumped...:wub::':)|
mfenn
22,400
www.mfenn.com
Sysprep is not 100% guaranteed to work on dissimilar hardware, it's meant for IT guys who are blasting an image out to a bunch of identical machines. Like Paperdoc said, certain drivers are installed or not installed based on what hardware is detected at install time. Sysprep also wipes out your user account settings IIRC, so be prepared to spend a lot of time setting everything back up.
DF-1
people say that sysprep installs the new hardware/drivers, but some say its not working on their systems..
do you recommend just trying install repair? or trying the sysprep guide in sevenforums? both?
also i backed up my whole Users folder in case anything happens to my F3 1TB.
If I install windows to my F3 1TB, can I use both hard drive's with their current data without a problem? or will there be programs I cant use because of registry?
mfenn
22,400
www.mfenn.com
As far as I'm aware, a "repair install" as such no longer exists in Vista or 7. You might as well just bite the bullet and do a fresh install IMHO. You will have to reinstall any programs that depend on the registry either way (which is most of them).
DF-1
ugh, when I try to run sysprep i get this error
I upgraded from win7 RC to retail, I think thats why.
googling it says I can delete something in the registery, problem is, its not in there!
i have ~ an hour before I have to finish this and take the HDD's out. any help would be much appreciated!
mfenn
22,400
www.mfenn.com
We'll you've probably already left by now, but I hope you took Windows media with you! You're probably gonna be doing a reinstall.
DF-1
Hey guys, just wanted to say, im on anadtech forums from the same bookmark.
unplugging replugging without doing anything else worked great.
