2001 Buick Regal. Why does the car steer easier when the traction control is turned on?
Because that's what traction control is designed to do. Give better traction (and before I get flamed, it has it's uses, don't want it for better performance then turn it off). Are you pushing it in corners or saying the feedback from the steering wheel is easier?
There shouldn't be any difference in steering effort regardless of whether the traction control is on or off. All traction control does is limit wheelspin.
ZV
I'll go out on a limb (or play Devil's Advocate) and say that with traction control turned on, if you're mashing the throttle, you won't be subjected to as much / any torque steer compared to traction control turned off, which will make it easier to turn.
On the other hand, if you're just steering normally (light on the throttle) it should make no difference.
We'll chalk that up to you being buzzed, since it is Friday nightYou make a very good point about torque steer. Wish I'd thought of it.
ZV
That car is FWD...not like it's much of a performance car.
