trackball explorer replacement
jkresh
I have been using a trackball explorer for about 5 years now and it is dying, cleaning no longer solves the problems. I would like to replace it with a trackball but I also game a bit, and it looks like most current trackballs (either kingstons high end ones, or logitechs cordless) are even less suited to gaming then my current one. Any suggestions on what to buy would be appreicated.
When my original Trackman Marble FX finally got too gimpy for me ;( , I went and got a Marble Mouse and it works OK for me. At under $20. it won't break you to try it.
.bh.
Thanks, I have actualy used one, but I dont feel that it is a viable replacement, would probably go to a mouse if that is the best thats currently available.
