I picked up this Router dirt cheap: http://wiki.openwrt.org/toh/tp-link/tl-wr1043nd Also using it with this Wifi Antenna instead: http://www.amazon.com/Cisco-Linksys-Wireless-N-PCI-Adapter-WMP300N/dp/B000FDDUXG
I was using a Linksys WRT54G v.3 with Tomato (Toastman) firmware.
I have my place wired with Cat6 and some Gigabit switches and transfer files between two PCs. So I was looking to get a Gigabit router sooner or later. I use Wifi for my phone, tablet, etc....
So now I am figuring which Firmware to use on it.... Stock, DD-WRT, OpenWRT, Gargoyle or some other 3rd party firmware I didn't list?
I have a 10mb net connection. Have a 3TB USB3 hooked up to one PC and have backups of the second PC backup on that drive. I am thinking of plugging it in the USB port on the Router but it will be limited to USB2. In time I plan to backup my DVDs and BluRays and view them between the two PCs.
Right now I threw DD-WRT on it. However someone from this site said: http://joeyiodice.com/converting-tp-link-tl-wr1043nd-to-dd-wrt#comment-2059
"A word of warning, DD-WRT does not support large or jumbo ethernet frames, which are supported by the TP-LINK hardware and stock TP-LINK firmware. This could give you a significant performance hit if LAN speed is important. In my case I benchmarked ftping 2GB files from my PC to my Synology NAS at 80MBps (thats Megabytes / sec) with stock firmware and jumbo frames and 31MBps with DD-WRT. Had to stick with the TP-link firmware, for most people it wont be an issue, but if you move lots of large files around your network, it certainly will be an issue that jumbo frames are not supported. Other than that, DD-WRT works well."
When looking up why DD-WRT doesn't have this feature some said that with faster CPUs on routers it's not needed? http://www.dd-wrt.com/phpBB2/viewtopic.php?p=662667&sid=cc4ea9fdc0af0ff005617ef78869b59e#662667
Also: http://forums.anandtech.com/showthread.php?t=2346098&highlight=wr1043nd
So just debating which firmware to use.... How much can I increase the Wifi Antenna DB? Any recommended settings? Like for Wifi do I use 20hz or 40hz or Dynamic?
I was considering a Dual Band N router but I don't know if I need it as my property isn't close to neighboring Wifi and I like to use Wifi while outside so 20hz 2.4ghz would be better for distance right? Plus my net connection is only 10mb. Course 5ghz might be better in the House?
Just curious. This seems like a decent Router. A bit better than my classic WRT54G.
Got it for a great deal and since it supports 3rd party firmware makes it a bit more awesome.
