Toyota maintenance for 1998 Corolla... timing chain/belt?
DonIsHere
My car is at 60,000 miles right now. I scheduled an appointment at my local Toyota and they said at 60,000 miles, they recommend changing my timing belt. Should I go for it?
don
unless you want to change it yourself
did they give you a price? it usually runs $100-$300 depending on if they have to remove the radiator or any other major parts to get to the cover
i changed mine on my '90 mazda myself, at about 70K miles, i haven't changed it since , it is now at around 160K miles , hopefully it doesn't break before i junk the car . the belt i removed at 70K miles looked almost as good as the brand new one i put on
don
Yes and also have the water pump and front seal replaced at the same time. Abd you don't have to have the dealer do it. You can have a good mechanic do it a lot cheaper.
Originally posted by: JJWalker
I'm pretty sure your 1998 Corolla has a timing chain. Not a belt.
Oops.. I know on the phone they said "timing-something". I was too busy contemplating the possibility of plunking down >$100. (hehe) Is a timing chain more expensive than a timing belt?
Seriously, thanks for the feedback so far.
It appears that I'm right.
And if I recall correctly, there isn't a time/mileage interval for it's replacement.
yeah, i thought (i am not a "car guy") that chains lasted much longer/only need to be replaced if worn/broken
After doing a bunch of reading, the only thing that I could find is to change the chain when it starts making noise. Hope that helps.
Just looked it up. 1998 is the first year the Corolla has a timing chain. Now what month and year was your car made? If it is a early 98 it may still have a 97 engine and still have a belt. If it is a true 1998 1.8L 4cyl and has a chain, you do not need to change anything.
I just got back after dropping off the car. The guy that took my car in said that replacing the timing chain wasn't necessary at all. Looks like the person I talked to on the phone didn't know what they were talking about. (whew)
I don't know what month the car was made, but I bought the car June 1998. I wish I could look it up right now, but the car is at the dealership right now.
Thanks for all the help.
chain == teh winnar!!!
(or whatever you kids say
Nah, no belt or chain is the winnar.
I like engines without them, no need to worry about another part needing to be replaced...
