I?m having a spurious lockup problem with my MSI K7T PRO2-A and My GeForce 256 DDR Video Card. My OS is Windows 2000 professional. My video card is a Creative Labs GeForce 256 DDR video card. I bought it OEM. It?s model number is (CT6970) and therefore it has the Nvidia BIOS as opposed to the Creative Labes BIOS. Since I can?t install the Creative drivers I?m using the latest Nvidia drivers for it (Version 6.31 for Windows 2000) which is fine. Unless I flash the BIOS of my card with Creative?s BIOS, Creative?s drivers will not recognize my video card as a Creative product and therefore won?t install properly. Now for my lockup problem: My PC is locking up when I leave it running a 3d screen saver for a while. I?ve tried many different ones and it happens with all of them. It will run fine for several hours. I will go to use my PC and the screen saver will stop as it should when I use the mouse and everything will be fine but when I come back to it the second time it will have locked up completely. The last image of the current screen saver will be frozen on the screen and I have to reboot. I am 100% positive I have the correct drivers and they are installed properly. I have made the following adjustment to my BIOS as an attempt to optimize the functionality of my video card:
1. Assign IRQ to VGA = Enabled
2. VGA Palette Snoop = Disabled
3. Video BIOS Shadow = Disabled
4. C800-CBFFF = Disabled
5. AGP Aperture Size = 128 MB (I have 256MB of system memory)
After all this it still happens. This isn?t a HUGE issue but I?m a perfectionist and I want everything to be 100%. I?ve never had a lockup or crash while using the PC, and I have never had a lockup using a regular 2D screen saver of no screen saver at all.
So, my question is: Is there anything else I can try (Other than buying a different video card) that will perhaps make this problem go away? Thanks for any input ahead of time.
