i have narrowed my choice for a 19in monitor down to the Samsung 900NF and the NEC FE991SB. any opinions on either...or another similar quality/price that i should be thinking about. thanks.
I would go with the Samsung, thats just because I have a Samsung and have had absolutley no problems with it. Thats just a personal preference. Go with what you like best.
