Total System Reformat........
AcidzT
67
its that wonderfull time of year again!
Yeah i need to wipe my system and reinstall everything, there are a few reasons. And its been a long time since my last one and the crpa is pileing up.
Im wondering if there is a program that i cn use to print out a list of all the programs i have stored on my computer. It would make my process 100 times easier..... any help?
stndn
1,886
yes, isn't it wonderful to be formatting your computer? used to do that once a month (old computer). glad those days are "over" ;)
anyways, i don't know how to list the programs you have... i know though that you can do a "dir /s" to list the files you have on your drive... one of the things you may want to do is go to the program files and list the directories directly under it, since most of the programs are installed under c:\programfiles by default (unless of course if you change them all the time)
i don't use outlook, so i can't really help much... but you may want to consider doing a search or read this, this, this, this, or this
-962-
