Toshiba S300-EZ2501 Using DVI on port replicator PA3508U-1PRP
StarsFan4Life
1,199
I have a Toshiba S300-EZ2501 laptop and a PA3508U-PRP port replicator/docking station. This docking station has a DVI out on it.
I also have a Viewsonic VX2235WM-3 with DVI in support.
For the life of me I cannot get the DVI portion to work. I have tried using strictly just a DVI cable and selecting the dvi/digital input. I have restarted. I have done just about anything I can think of. Is there something I have to do special to get the laptop/docking station to work on my DVI output?
The VGA works fine on this.....but is VERY blurry and hard on the eyes. DVI should really help with this.
mpilchfamily
3,559
Best information i can find concerning the issue looks like you already know considering its from your identical thread you posted at: http://laptopforums.toshiba.co...PA3508U-1PRP/m-p/37789
My guess would be if the VGA is blurry then the DVI probably isn't going to be much better. As mentioned at that other forum there may be a firmware update that will fix this problem as it seams your not the only one having this issue.
