- Jan 29, 2006
- 45
- 0
- 0
I have a TLP-S71 Projector. When I try to start it up, it lights up the "on" light and the "lamp" light blinks for about a minute. The fan starts turning, and this continues for about a minute (this is similar to its normal startup procedure).
Then the "lamp" light stops blinking and the "fan" light turns on for about two minutes. The lamp still has not turned on. After the two minutes, the "fan" light turns off and the fan stops blowing. The projector just sits with the "on" light on and does not project.
The projector is connected to a computer and a document camera, both of which are on and connected. I replaced the bulb in the projector a few months ago, so it is fairly new. I realize that this is a very specfic issue, but any thoughts would be appreciated.
