HP ze5375 laptop with 40GB Toshiba drive that died a loud, horrible death. Can replace with a slightly faster (5400RPM v 4200) for $66 or spend an extra $8 for a Seagate with 16MB cache. Which would you go for?
no im just saying, a when you buy a cdrw drive, most of the cheaper models have 2mb of cache. that is barely adequate. 8mb is pretty much the norm on most hdds. 16 mb is great. for such a minimum increase in price, get it.
I just got a new laptop - H_ dv1000 series, and it came with a Seagate 5400 RPM 80GB Momentus drive. It's OK - but I just replaced it with a Toshiba 5400 RPM 80 GB drive (from NewEgg). The difference is the cache. Toshiba is 16 MB and Seagate is 8 MB. In actual prtactice, the Toshiba is quieter and performance is better. The Seagate is now a ready reserve backup drive.
