toshiba laptop problem need help
dorky82
250
I have toshiba satellite m35x-s149.
I'm getting this error in bios
Resource Conflict - PCI Network Controller on Motherboard
Bus 02 Device 02 Fuction 00
Now its giving blue screen in windows.
anybody know what this device is? I'm hopeing its wireless mini pci(then I can just pull it out)
thank you
JimPhelpsMI
1,261
Hi, I don't have a late Satelite, but have worked on many laptops. Laptops do not have PCI slots. The lan driver an other devices are part of the mother board. They are the same chips as are found on PCI cards and use the same drivers. You wont be able to just pull it out. If it's A PCMICA card then you can just pull it out. Good luck, Jim
