toshiba laptop help
turtle515
I desperately need help.I have a toshiba laptop,specs below.I STILL have dialup and the laptop has no modem.I purchased an external modem and hooked it up to the laptop.I can get online but it will only stay connected 5 to 15 minutes.I have searched and searched for a solution to this problem(including talking with Toshiba reps)without a solution.I thought maybe it was the modem but after hooking it up to my desktop that's not it,it worked with no problems.Sure hope somebody can help me out.Satellite L355 Detailed Product Specification1
Model Name: L355-S7915 Part Number:
Operating System
C1
• Genuine Windows Vista®
Home Basic (SP1,32-bit version)
Processor and Chipset
• Intel
Celeron®
processor 900
o 2.20GHz, 1MB L2, 800MHz FSB
• Mobile Intel
GL40 Express Chipset
Memory4
• Configured with 3GB DDR2 800MHz (max 4GB)
Storage Drive5
• 250GB (5400 RPM) Serial ATA hard disk drive
Fixed Optical Disk Drive6
• DVD SuperMulti drive supporting 11 formats
o Maximum speed and compatibility: CD-ROM (24x), CD-R (24x),
CD-RW (24x), DVD-ROM (8x), DVD-R (Single Layer, (8x)),
DVD-R (Double Layer, (4x)), DVD-RW (6x), DVD+R (Single
Layer, (8x)), DVD+R (Double Layer, (6x)), DVD+RW (8x), DVD-
RAM (5x)
Display7
• 17.0” diagonal widescreen TruBrite®
TFT LCD display at 1440x900
native resolution (WXGA+)
o Native support for 720p content
Graphics8
• Mobile Intel
Graphics Media Accelerator 4500M with 128MB-1342MB
dynamically allocated shared graphics memory
Sound
• Built-in stereo speakers
• Sound volume control dial
Input Devices
• 104 US keyboard with 10-key
• TouchPad™ pointing device
• TouchPad™ Enable/Disable
Communications
• 10/100 Ethernet
• Realtek
802.11b/g wireless LAN9
Expandability
• 2 main memory slots. Both slots may be occupied.
• ExpressCard™ slot (ExpressCard/34 and ExpressCard/54)
Ports
• Video
any help would be most appreciated,thanks
With the modem installed go to device manager and see if there are any "!" up at all.
If not, check for any type of Windows updates you may be missing.
Is there any other way to try a different type of modem out on your laptop? (I was a laptop repair tech and there were a few ways to try this out with modem issues.)
Do a google search for any known incompatibility problems with your modem.
Is your desktop using the same line as your laptop?
