Originally posted by: QuitBanningMe
I do the same.
I haven't downloaded anything for over a month but I've been seeding the whole time.
Bram:
That 'functional glue' is extraordinarily difficult to get to work well. Ever-changing network conditions and very high rates of peers disconnecting produce a very thorny logistical problem. Most existing swarming implementations don't even manage to fully utilize all the upload capacity available to them.
That said, there are other decent swarming implementations. For example, the one in eDonkey is quite serviceable, and Furthurnet's works okay as well. BitTorrent handles the little details of file transfer better than all of the others, but if that were the only difference its advantage would be relatively minor and subtle.
What sets BitTorrent apart is its very robust technique for rewarding specifically the peers which upload the most, known as leech resistance. On the highest level, this prevents a long-term meltdown of the system from being caused by people running leeching clients. It also causes upload and download rates to be somewhat correlated, so peers on good pipes get decent download rates, which increases general good feeling about how the system behaves. Overnet, the follow-on to eDonkey, may start using BitTorrent's peer protocol in the future specifically for the leech resistance properties.
By the way, people sometimes run clients hacked to not upload at all and still experience good download rates. Usually this is because they're downloading a file which has been available for a while and there are many clients which have finished downloading but been left running, so there's plenty of excess bandwidth to go around. Not uploading in a swarm which is still ramping up is generally ruinous for download rates.
Originally posted by: dighn
cap your upload. you can't make others upload faster but at least you can prevent yourself from getting suspend by the ISP for overusing bandwidth.
Originally posted by: JustAnAverageGuy
I seed whatever file I have until the share ratio hits 1.00, then I remove it from the list![]()
Originally posted by: Amol
Downloaded: 73.51GB
Uploaded: 29.24GB
Ratio: 0.397
Thanks for making up for my crappy upload speeds
See, even that doesn't really help out, because when you're uploading while you're download is incomplete that counts towards the ratio. However, that doesn't help out the seeder much, especially because most people don't have super-seeding on. Always try to up the file size of the file AFTER you've completed it in addition to whatever else you've already upped.
IMO, it doesn't really matter which part of the file you help distribute, It's that you helped distribute and also that you took the burden off the people that do have it.![]()
Most of my downloads around the .3 or .4 range when they finish though. So I still get a good distribution of the file out there![]()
I put back what I take. Most of the swarms are 2K+ people though.
If it's a small swarm, I don't have a problem going past 1, but if there are that many people, I'm just going to do my part and go home![]()
Originally posted by: 0roo0roo
worst of all is the seeder who spams bad packets. damned mpaa/riaa
Something I always wondered was in P2P programs such as WinMX, Limewire, BearShare, etc., who were the fvckheads who uploaded songs that were popular singles and about 10 seconds into the song turned into total scratching/rubbish? Was it the RIAA?
Originally posted by: Crazyfool
They never go after the leechers only the people who share for weeks on end. (doesn't anybody remember all those Kazaa users being sued for sharing mp3s?)
Hit and run is the name of the game, matey. :laugh:
