I'm still back in the Geforce3 and 8500 era (cause I'm cheap) but I can't let these get by...
-It has Dx9 support, yes, there is no game using it right now but they're out soon and if you have Ti4600. Well...it's just too bad because 9500 Pro will burn Ti4600 since its optimized for dx9.
Rollo explained this already. VGA cards aren't future proof. Buying a card for "tomorrows" games is a bad plan since "tomorrow" there will be better and cheaper cards which are available.
-9500 Pro has AGP 8x support. Ti4600 doesn't and the lowest priced Ti4600 with is around 220 bucks which is a lot more expensive then a 9500 Pro and if you might as well just get a 9700 instead.
AGP 8x support is generally meaningless. Performance imprevements are in the order of 1-2%. Besides, he talked about getting the 4800 which is AGP8x
-All 9500 Pro are pretty much the same, not all Ti4600 are the same. Different manufacture uses different settings and in order to compete well with 9500 Pro. Well, you need a higher priced Ti4600 around ~230 and that is without 8x support in most cases.
Err, see above. The 4200's are actually the best bet and those are in the 100-125 range.
-9500 Pro has superior image quality then Ti4600.
Probably depends on the specific manufacturer, but I couldn't say because I haven't compared a 9500 Pro with a Geforce4 on the same monitor. Have you?
-9500 Pro has more pipeline then Ti4600
# of pipelines is just architecture. Performance/price is what matters.
-9500 Pro drivers are constantly improving and you're worried about stability and compability well there are unofficial drivers which does a even better job then official ATi driver. ie Omega driver.
I trust BFG10K on this one. He generally calls it like it is and he seems pretty happy with the state of ATI drivers on the 9700. Then again, I've personally been pretty happy with nVidia drivers.
I dont think anyone argues with the benchmarks. With AF and AA, both the 9500 and 9700 are excellent cards for the $. If the high image quality which AA and AF provide isn't a high priority to you, the GF4 is still a very good solution. Stable and very high performing at default settings.
