Toothpaste (with baking soda!) Removes heatsink paste and that nasty discoloration too!
ss284
=) From experience baking soda works best. I used whitening with baking soda.
works great, better than an alcohol pad or a wet tissue/rag
The bottom of my taisol is silver again, instead of that black/grey color!
let me know how it works for you guys,
-Steve
sharkeeper
10,886
Toothpaste actually contains a mild abrasive. You could do the final lapping stages with it as well. It's also good for polishing minute scratches out of compact discs.
Cheers!
UKspace
Banned
Dec 15, 2000
343
You learn something new everyday!
Oh, the wonderful uses of toothpaste. And I thought it was to clean your teeth! ;)
Any brand of toothpaste particulary useful or are they all the same?
bacillus
14,517
<< The bottom of my taisol is silver again, instead of that black/grey color! >>
can you recommend a particular brand? :D
sharkeeper
10,886
Some are more abrasive than others. Particularly abrasive are the ones for removing nicotene and coffee stains. Placing a glob of this on a 12x12 highly polished marble tile and rubbing in a orbital motion will definitely polish the HS very nice. If this is an unfinished HS with millmarks you'll need to sand it with 400-600-800-1200 at first to at least achieve a partially mirrored finish.
Cheers!
ss284
I use colgate extra whitening with baking soda!
seems the baking soda adds to the abrasiveness. yet somehow, toothpate cleans the bottom residue, resulting from the chemical reaction frmo HS paste and the heatsink.
-Steve
