Toothpaste is not only for cleaning your teeth!
Taejin
Moderator<br>Love & Relationships
Aug 29, 2004
3,270
OMG TOOTHPASTE IS DA BEST YO I CLEANED MY CDS WIT IT AND IT ROX!
AQUAFRESH TO THA GRAVE!!!!! EAST SIDE
seriously though. Toothpaste -> poor man's alternative to cleaning solutions (for CDs)
Taejin
Aug 29, 2004
3,270
Originally posted by: AStar617
Is rubbing alcohol that expensive? :confused:
When you are poor, even the toilet paper for wiping your butt is expensive.
Icepick
3,663
4
Another use is to fill up tiny holes in your dry wall. You know, those holes left by an old picture hook that no longer has a painting hanging from it? Just put some toothpaste on a toothpick and dab it in that little hole. Works like a charm.
Vich
2,849
unless u got the toothpaste with multi colors! :Q
HighTich
8
its also good for clearing steam off a mirror when shaving. I also use it when I snorkle, just wipe it on the mask and you dont have to worry about the mask fogging up.
Gravity
5,685
No doubt, peanut butter and tuna on the menu for a month!!!!
meltdown75
37,548
7
You can use it as thermal paste for your CPU. I forget where the link for that site is... some guy used many different substances for thermal transfer on the CPU / HSF and toothpaste was one of them.
Scarpozzi
26,392
1,780
It's what they recommend you use on dive masks when you first get them. The low-abrasion cleaner can remove the chemical film from the manufacturer on the glass and keep it from fogging up as bad.... It works great.
Reckoner
10,851
Maxim subscriber eh? ;)
