- May 11, 2005
- 219
- 0
- 0
I am going to be using the Aspire X-plorer mid-size case. This case natively has five fan positions (2 front, 1 side, 1 rear, 1 blow-hole - all 80 mm). In addition to this I was going to add a set of drive fans, and a duel pci-car fan system that extends into the case and allows you to direct in or out flow. Overall this would give me 9 case fans not including the powersupply, CPU or Vid card fans.
I am not too worried about noise. The case has a 4-fan group controller standard and I am getting an Aerocool Gatewatch II to control 4 more. This will also give me a total of 5 temperature sensor probe positions. And to top it all off, I intend to use headphones for sound.
I have a couple of questions that people can feel free to flame me on.
(Not going to overclock anything, I just like the idea of fan cooling...)
1) What problems will I run into with this many fans? Does too much airflow cause issues I may not be realizing?
2) Am I going to have power supply problems? (Besides the number of plugs)
3) At what point will the case hover off the ground?
4) At what point should I give up the pretense of having a case and just take off the side panels and replace them with box-fans?
Thanks for everyones input in advance!
System specs:
AMD FX-55
Asus SLI deluxe MB
Duel Leadtek 6800 Ultras
OCZ 2x1024MB Ultra low lat mem (2-3-2-5-T1)
72 GB Raptor
300 GB WD Storage drive
System specs:
AMD FX-55
Asus SLI deluxe MB
72 GB Raptor
