marmasatt
Ok, my system is in my sig. It is all housed in this joint here.
I've got the fan on the side window blowing in on the mobo. The blow hole on the top going out and two 80's in the back - one suck, one blow. My internal case temps are going through the roof. I'm looking at 104F non load up to 114F - 118F load. Everything else is fine, I think CPU 45C non to 50C load and a littler lower for the mobo temps.
Performance is so/so but with this hot weather I'm starting to run into chopiness on some games that I wasn't seeing before. Not too mention, my internal case temps used to linger around 85 - 90F. I think I've got to do something.
Any suggestions here? Should I make both fans in the back blowing out maybe? Get better fans? LMK. Thanks.
Oliver
Oliver
