Too high case and CPU temps?
Zincq
369
Case - 49 degrees C
CPU -
Idle: 55 degrees
Working: Anywhere up to 60 degrees
I need better air flow - but the back of my case can't fit a 80mm fan, not enough screw holes. I'm not sure of the size, but maybe it's a 60mm? And have 1 80mm in the front, intake.
Dec 13, 2001
185
Well your case temperature seems really high. No AC? Once you get your case temps down I'm sure the cpu temps will follow.
Zincq
369
Right on, I took off my case side and put a house fan right next to the computer. Temperatures fell dramatically and have been stabalized at Case=38 degrees, and CPU=45 degrees.
kyoshozx
588
97 C ???? and your cpu is still functioning? what kind of cpu is that? It's above safe operating temperatures for most cpus.
Anubis
78,712
427
tbqhwy.com
Originally posted by: dmcowen674
Case 160 F
CPU 97 C
Room 150 F
PC's - running no case Fans, no problems. Only CPU fans to curb thermal runaway.
ok your room cant possibily be at 150 F somethin wrong with your readings
Profyrion
43
Case 160 F
CPU 97 C
Room 150 F
:Q
Riiiiiiiiiiiiight...
dmcowen674
54,889
47
www.alienbabeltech.com
The room is a wired room in the attic. The PC's are 2 AMd's and 2 Intel's at 1 gig or better. This has been witnessed by Anantech Distributed Computing members as well as local News Media from NBC here in Atlanta.
I'm a 25+ year Electronics Hardware Design Engineer. I have helped design many products that have become standards today such as old time Modems from Hayes as well as ADSL modem.
You could say the room is my own personal "Burn in" room for electronics. As long as you run the electronics within the maximum design spec and have a heatsink/fan that stops THERMAL RUNAWAY you are OK. Heat failure can only occur from a Thermal Runaway condition not actual operating temp that is within spec.
