nitromullet
- Jan 7, 2004
- 9,031
- 36
- 91
Dude let's just forget it. You can't make an argument when they think we don't know math while we think they don't understand English...
LOL! Point taken.
No. It means it does the job in 2x longer time. We measure time. Time. Need I write it one more time? Oh sorry,I already did
100% slower is actually 2x slower than the base you are using. Which is 50s in the (hypothetical) example original poster used.
Do we all understand that MORE time is SLOWER ???
Does 100 seconds are DOUBLE than 50 seconds ??? Does that makes the processor that needs 100 Seconds being 100% SLOWER than the processor that needs 50 seconds ???
Do we all agree to that ??? no matter if we know math or understand English ???
ps: IDC, you seriously have some problems, i will suggest you take the following, it works 100% (i have used it my self)![]()
http://www.powerhealth.gr/en/product/mens-x-complex-2/?gclid=CKzC5eHu27MCFczHtAodejQAaw
Instead of saying slower, just say it takes 100% more time.Do we all understand that MORE time is SLOWER ???
100% slower than something would mean it is doing no work at all.
100% slower is an infinite amount of time.
50% slower is 100% more time.
heh, Resistance is Futile![]()
100% slower means 100% more time, period.
No. both "slower" and "faster" do not refer to time alone. They refer to speed, which is a function of time.
Speed = distance/time.
On AT speed is slightly more abstract because we don't usually talk about the speed of cars or other physically moving vehicles. We usually refer to speed as some unit of work/time. Frames/second is probably the most common example.
The percentage refers to the work units done per second.
- If cpu A is doing 100% less work units per second than cpu B, cpu A is not doing any work.
- If cpu A is doing 50% less work units per second than cpu B, cpu A is 50% slower than cpu B, and cpu B is 100% faster than cpu A.
50% better performance? How about some facts from the article? Time to completion of whole THG test suite(ST and MT workloads) for 3970x is 91.5 minute. FX8350 took 116 minutes . From this we have: 91.5/116=0.788 or ~21% faster than 8350. 3770K is similarly 12% faster than 8350 when you take its total runtime in the equation.
Okay promise I will stop after this post because it's pointless.
Those of you arguing against nitromullet and me: The problem is I can tell based on your posts neither of you are native English speakers. Why? Because things like "less faster" are not proper English. This is why we won't ever understand you and you won't understand us. As I explained, you cannot resolve an argument when one side thinks math is the problem while the other side thinks English is the problem. I don't mean this to be mean but you guys simply DO NOT UNDERSTAND ENGLISH PROPERLY. That is the problem. Now let's please put this to rest.
It has nothing to do with understanding English or not, it has to do about acknowledging the fact that the OP was talking about TIME and Less time is FASTER.
Taking LESS time to do the same thing is FASTER, now when people argue that faster is not about time but work done in the same time i beginning to believe that someone here is trolling or, im sorry to say, he or she is stupid.
Also, people are too proud to admit they are wrong in this forum. Nobody knows everything(except me).![]()
Computer A finishes a task in 10s resulting in benchmark score of 10 A.U. (arbitrary units)
Computer B finishes a task in 5s resulting in benchmark score of 20 A.U. (arbitrary units)
Computer B finishes a task in 5s resulting in benchmark score of 5 A.U. (arbitrary units)
We have two different kinds of benchmarks, one type is the type that results in a number where the higher number is "better" i.e. "faster"
Data Type 1:
The second type is the type that results in a number where the lower number is "better" i.e. "faster"
Data Type 1:
Goal - develop an objective method for ascribing adjectives and numerical percentages which capture and correctly convey the relative performance differences between Computer A and Computer B regardless whether we are assessing the results of Type 1 benchmarks (higher is better) or Type 2 benchmarks (lower is better).
With that, I yield the floor to those of you who wish to weigh in with your proposals![]()
I think on the Car 2 there is some inaccuracy.Time: lower = better
Car 1 travels 100 km in 1 hour.
Car 2 travels 200 km in 1/2 hour.
Car 2 is still twice as fast as car 1. Car 2 completes a task in 50% of the time.
To me, if you're moving 100% slower, you're not moving at all(def #2).
You can move infinitely faster, but you cannot move infinitely slower since you can't move slower than 'no movement'.
If it makes more sense,I think on the Car 2 there is some inaccuracy.
If Car 2 were to be *twice* as fast as Car 1, then wouldn't you only double the km or halve the time as opposed to both?
Car 2 should travel 100 km in 1/2 hour to be twice as fast as Car 1
or
Car 2 should travel 200km in 1 hour to be twice as fast as Car 1.
kevinsbane said:Car 2 is still twice as fast as car 1. Car 2 completes a task in 50% of the time (compared to car 1).
So how would you like to define "100%" faster?The confusion is because you re doing an amalgam between "X% slower" and "Y% less" (time...)
You can move as much slower as you want it will still be superior
to 0 wich is the boundary of "infinitly slow".
Hence , being 1000% slower means a 10 ratio in "slowness".
It s the same as saying that it takes 90% less time , see ??..
100% slower = stopped
Both statements are true at the same time.
I stand corrected.I'm not so sure.
Translation:
Car 1 travels 100km in 1 hour = 100km per hour.
Car 2 travels 200km in 30min = 400km per hour.
100% slower is twice as slow , mind you...
So being twice as slow would be stopping ?...
Actually it is going at half the speed.
