apoppin
Yes, it is evidently a HW issue with my HD 6990I've had that several times over the years. Either the gpu wasn't seated properly or the cord was loose.
edit: n/m, looks like you're having problems again.
Cliffs:
- It worked fine for my evaluation and for heavy use for a few weeks. Then i detoured into a 3D Vision eval (back in the box for 3 months).
- Installed it into Intel PC and it artifacted badly; moved it slot to slot; driver changes - nothing worked - launching 3D apps BSoDs the system
- Emailed AMD. They said to put it into another MB - Ph II and it worked
- Back to Intel system - worked for a few hours. Upon reboot - same BSoDs
- Back to Phenom II system - and it works again
And the Intel system is fine - HD 6970 and even CF runs with no issues with nothing changed out but the HD 6990
i emailed AMD ... no response yet (i think there is an event they are all going to)
