Tom's Fan Failure Test
PetNorth
267
Originally posted by: keysplayr2003
BE-2300 is 1.9GHz
Core Voltage:
1.15- 1.20 V
E2160 is 1.8GHz
Core voltage:
1.225-1.325 V
So this statement: "If they undervolted and underclocked the rest of the CPU's to a E2160's frequency I am pretty sure that all would accomplished the same tasks." Is out the window.
Are you still pretty sure?
So, you can underclock the BE-2300 100MHz, but you'd have to increase the voltage to 1.225 or higher to equal the E2160. Or did you just want to underclock?
No. BE-2350 and BE-2300 Stock voltage is 1.25v
http://products.amd.com/en-us/...opCPUDetail.aspx?id=69
http://products.amd.com/en-us/...opCPUDetail.aspx?id=70
and E2160, 1.162V-1.312V
http://processorfinder.intel.c...tails.aspx?sSpec=SLA8Z
Techno Pride
139
Tom's article is only good for telling you what happens if your stock cooler fan fails. Anyone really interested to build a quiet PC would be using big heatsinks like the Scythe Ninja or Thermalright Ultra120. There're people running Q6600 with fanless Scythe Ninja.
21stHermit
927
In the open for sure, but not in a fanless case. Or at least not for long. :D
Techno Pride
139
Not sure about that. The dude was having the rear fan as an intake, so the Ninja always gets cool air. I think the processor was undervolted as well.
wwswimming
Banned
Jan 21, 2006
3,695
you know, i tried that once with a 3 GHz P4, the generation that used DDR-400.
i was about a half hour into installing XP, and noticed that the CPU was REAL
hot.
it helps if you can see the fan connector !
that system has run fine since then. it's my "learn Pro-E" system.
VirtualLarry
56,587
10,225
Originally posted by: Viper GTS
FWIW I have a BE-2300 system running fanless on a GeminII.
The only fan in the system is the 120mm in the Seasonic S12II.
It runs quite toasty (I need to loosen the mount on the GeminII as I may have over-tightened it) but it's orthos stable for hours on end. Needless to say it is one quiet system.
Viper GTS
How do you like the Geminii cooler? I picked one up, debating on whether or not to use it for my upcoming quad-core build or whether I should use my Freezer 7 Pro.
JEDIYoda
33,986
3,321
The Gemeni 2 is a nice heatsink...albeit CM`s take on the ThermalRight series of XP and SI120 the CM Gemini2 does a real fine job!
The Only drawback I see it that ThermalRight uses thicker aliminum fins for heat dissipation.
yet the Gemini2 is a real fine heatsink.
Is it comparable to the thermalRight XP120 or the SI120? Mosy definately!!
Peace!!!
Captante
30,353
10,878
Originally posted by: aigomorla
Originally posted by: nyker96
that's pretty impressive for E2160! now let's see if a fanless setup works for this guy, maybe a TR 120 UX can cool this guy fanlessly.
uhhh i have a E6300 cooled by an Ultra120EX passively. >.<
It doesnt do tons of encoding. Its a media center that basically plays movies, and streams off my NAS. But i havent had any problems with it yet.
I had an X2 4000+ running at default clocks for several weeks on a Zalman 9500 with no fan & it was rock-solid stable, in fact it ran cooler under load then it did with the included HS running the fan on high ... the THG article is more a test of the OEM HS's ability to cool passively then anything else.
As I recall in the original test they actually REMOVED the HS/fan from the cpu while running under load.
