Tomcat help...
AFB
I installed Tomcat 5.8? using the binarys. When I try to put a JSP file under the webapps folder I get a compile error? Any guides on how to do this?
tomcat *shudder*. I had horrible experiences with this. It took me hours to get it to work. My solution was going to an older version.
what do you mean? You just unzip it (or install it if you chose that distribution), set your CATALINA_HOME and JAVA_HOME environment variables and you're done. Put your web archive file in the webapps directory and startup the container using startup.bat or startup.sh depending on your OS. It's not rocket science and it hasn't changed since version 3 of Tomcat (there is no 5.8).
post the error here please.
on a related note can anyone tell me how the hell to turn off dir browsing in Tomcat? I cant find it anywhere
Done all of that, restarted many times
CATALINA_HOME = C:\Program Files\Tomcat 5.0
JAVA_HOME = C:\j2sdk1.4.2_03
Error below
Did check the log for the full stack trace like it says at the end of that error message?
The full stack trace of the root cause is available in the Apache Tomcat/5.0.28 logs.
